跳转到主内容
Dell Inspiron 9100 laptop with double row rear connections and 15.4 inch screen
Won't come on screen when turn on
Screen go blank after window xp pop up
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Does your screen remain properly visible when your computer stays on? Does your screen stay visible when you access the BIOS?. I would try a Linux Live CD and boot from that. See if your screen remains visible. Right now it does sound like a Windows problem more than a computer problem. Have you tried to safe boot windows and checked your drivers?
完成的
添加一条评论
2个答案
已选择的解决方案
Here is a link to a copy of your service manual. Good luck.
http://support.dell.com/support/edocs/sy...
这个答案有帮助吗?
得分 3
添加一条评论
First try to check your power supply using a voltmeter if your getting the appropriate voltages or not then try to re-install the windows by following steps:
In case you dont have a disk you can install windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start booting from USB).
Step 8- follow the on screen instructions to complete the windows installation.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aihvixaythong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 1,005
