跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Why can't I open my apps?
When I go to open any of my apps on my iPhone they will act like they r going to open then close out. I can only open the apps that came with the iPhone. And I have tried all the things the apple company (read on the internet) suggested to try
回答此问题 我也有这个问题
这是一个好问题吗?
得分 30
添加一条评论
11个答案
最有帮助的答案
This often happens if the apps were downloaded on an Apple ID with which you are no longer logged in, for example if you synced your phone with a friend's computer.
Try downloading a few new apps on your account to see if you are able to open those, or try an alternative Apple ID to which the apps might belong.
这个答案有帮助吗?
得分 5
5条评论:
Thank you for the advice, works perfect now.
完成的
what if the same thing is happening to mine but I have a iPhone 5s
完成的
@firecat_ My answer still applies.
完成的
But I can't do load apps
完成的
@ilovemannybae now all I have to do is try it I hope it really works.
完成的
添加一条评论
Do you have a jailbroken iphone? If do so you have have a tethered jailbreak and might need to use redsn0w to boot tethered now option.
Theres a new tool to untethered jailbreak the iOS 5.1.1 its very easy and works on the 3gs whit no problems, and eliminate the need to connect tue iphone to the computer on every reboot.
这个答案有帮助吗?
得分 3
1条评论:
No my phones not jail broken.
完成的
添加一条评论
My apps are not working they are not opening
Update (03/26/2016)
Yes need to get it fix
这个答案有帮助吗?
得分 2
1条评论:
a catch22 as no App can be open, is there a way to do it from a cmd line
完成的
添加一条评论
Thanks, Shelley! ;)
这个答案有帮助吗?
得分 0
添加一条评论
i need some next annoying apple ID which apperently isnt verified
这个答案有帮助吗?
得分 0
添加一条评论
I have this same problem too , I go into any app and even the apps that came with the iphone act like there opening the app then it just goes out the only app that doesnt do that is The Settings.....I have the IPhone 4 , IOS 7.1.2
这个答案有帮助吗?
得分 0
1条评论:
I am having the same issue, I only use this phone for music and games and most of my games have stopped working and other apps have now stopped working. I treat this phone like an IPod due to my actual phone doesn't have a lot of space on it.
完成的
添加一条评论
Just soak it in vinegar dash some salt on that ##&&% and let it sit for a few hours than your good to get on battlefield and team kill or text that girl you wanna eat out
这个答案有帮助吗?
得分 0
添加一条评论
Please open my handy app
这个答案有帮助吗?
得分 0
添加一条评论
It says I cannot open apps store.
这个答案有帮助吗?
得分 0
2条评论:
It's been like this for about 4 days
完成的
How do you I open apps on iphone 3gs when they don't want to open?It is a 6.1.6 version!I'm having a hard time figuring it out?
完成的
添加一条评论
Apple sucks! Im having the same problem in openning apps, I also have a 3Gs.... I can not even get more apps because I got a message saying: "This app requires iOS 4.3."
So apple launches new versions that make older ones obsolete, now my iphone is not smart anymore, just a regular phone that recieves and makes calls /sms...
这个答案有帮助吗?
得分 -1
1条评论:
Have you tried updating to iOS 4.3?
完成的
添加一条评论
iOS 4.2.1 is the maximum for iphone 3gs.
这个答案有帮助吗?
得分 -1
2条评论:
No, I have a 3Gs, i have iOS 6.1.6
完成的
iPhone 3GS is capable of running up to iOS 6.1.6.
完成的
添加一条评论
添加你的答案
Nicole 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 42,428
