跳转到主内容
Repair and disassembly information for the Google Pixel Tablet, Google's first tablet under the Pixel line of devices. Designed to be both portable and used within the home with the included charging speaker dock. Released June 20th, 2023. Identified by model numbers ‎GMD6Z or GTU8P.
Does this screen need to be replaced?
I wonder if this screen might be able to be repaired, and not necessarily replaced. Would it be worth it to take it off and reattach it to see if that fixes the problem, before I buy a new one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @scottvandekrol
Damaged (cracked) LCD screens cannot be repaired, they have to be replaced.
Here's the ifixit Google Pixel Tablet Screen Replacement guide, that shows what to do.
这个答案有帮助吗?
得分 2
2条评论:
thanks @jayeff. Just to clarify, I don't see any cracks on the screen, and thought maybe it might just be a loose connection?
完成的
@scottvandekrol
The screen's internal connections are a matrix arrangement of vertical and horizontal lines.
Loose connections result in black horizontal or vertical lines not curves.
Run your fingers very lightly across from a coloured section of screen to the black and check if you can feel a difference at all.
If you can't feel anything most likely it is internal damage that you can't see.
完成的
添加一条评论
添加你的答案
Scott Vande Krol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 142
