跳转到主内容
加入维修社区 - 创建账户
Frigidaire 制造的冰箱的维修信息、服务指南及故障排除帮助。
Resetting the reset indicators
Refrigerator: Frigidaire model GRSS2652AF
Age: Just past the warranty period
Both the ‘Reset water filter’ and ‘Reset air filter’ indicators are on. The manual clearly states “15: Air Filter The display shows the current status of the air filter (Good, Order, or Replace). To reset the filter status to Good, press and hold Air Filter for 3 seconds.” I have done this, but the indicator is still lit. Exact same thing for the water filter.
What else can I try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Replace filter,makes ice no water
由完成的 分享
@arthurfranklin
Try pushing the filter in a fraction more so that you hear it click.
If it won't go in any further, turn off the water and remove the new filter and reinsert the old filter (until you hear it click into place) and check if you get water.
Sometimes replacement filters if they're not OEM are not exactly the correct specifications regarding the tabs so it doesn't quite fit correctly to open the valves in the filter housing when it's inserted.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Can't say for sure, but have you tried physically removing and replacing the filter? If it has sensors such that it can tell if it's installed then it might not allow a reset unless it thinks the filter has been replaced.
这个答案有帮助吗?
得分 1
1条评论:
My understanding is that the filters are simply timer based and that they do not measure anything.
由完成的 分享
添加一条评论
添加你的答案
Gerry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 1,346
