跳转到主内容
加入维修社区 - 创建账户
The Nokia 7.1 Android smartphone was released by HMD Global, a Finnish mobile phone company, under the Nokia brand. The 7.1 was released in October 2018 and is an upgraded version of the Nokia 7.
Phone hasn't been used in a long tims won't turn on
Hi I've got this phone out of storage and the phone won't turn and are looking for advice
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Me pasó algo similar. No es la batería, ni el PIN de carga. Se trata del integrado P NIC que está junto al procesador. ¿Cómo puedo removerlo sin dañar la placa?
完成的
Thanks for the head up about the chip. I haven't actually got round to doing the battery even. How did you find out it was the chip?
完成的
And any instructions to rep[ace the chip
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @jamesjewess
Chance are that the battery has failed and would need to be replaced.
Does the phone indicate that the battery is charging when a known working, compatible charger is connected to the phone?
If it does, keep the charger connected for at least 2-3 hours and check if the battery now starts to charge. Allow it to fully charge before attempting to turn on the phone.
If it doesn't indicate that it is charging or even if it does but never charges and starts, replace the battery and check if that resolves the problem.
Here's a video that may help.
Search online for HE340 battery to find battery suppliers that suit you best.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the advice will have a look tomorrow and get back to you
完成的
添加一条评论
添加你的答案
James Jewess 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 92
