跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
MacBook Pro wont charge after battery replacement
I finally changed my macbook pro's battery with an ifixit replacement after mine had the "service" warning showing for a while. I did the install and the calibration. But noticed it kept switching from charging to plugged in but not charging. I reset the SMC and it kept doing it. I dig diagnostic and shows normal. I went in and unplugged the battery, held down the power and turned it on with only power from the power supply connected, turned off, plugge dbattery again and turned on. It works for a bit but will eventually go back to plugged in but not charging. Not sure what to do as this was not an issue with the original battery, even tho it lost charge quickly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you monitoring the battery temp? The battery won't charge if the battery is too hot. This is a safety feature, stop and active programs, take a snapshot of CoconutBattery, put the system to sleep letting it rest for a few hours or over night wake the system give it a few minutes and run CoconutBattery again is it charging now and the temp lower?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hernan Diaz Montalvo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 60
