跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly information for Sony WH-1000XM3 wireless noise-cancelling over-ear headphones.
Headset won't charge or turn on
I dropped my headphones and broke the headband on the right earcup. Was able to to reassemble the head band and the headset worked for a while but now it won't turn on or charge anymore. The wire in the headset is kinked but I'm not sure if that's the cause
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
That is quite normal for those wired to be kinked a little. I believe it could be that your battery connection got dislodged or other components of the motherboard in the cups broke off. Do you have a photo of the disassembled earcups?
完成的
It was actually some wires touching in the left ear cup. Found a a guide that fixed it
完成的
添加一条评论
1个答案
Found this guide on here and and it was actually the solution to my problem
SONY WH-1000XM3 Teardown
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Grant Vrban Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 276
