跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
Touch ID not working after MacBook reassemble
I tore down my Macbook Pro to clean the dust off.
During the disassembly process, I didn't touch the Touch ID connector. I just removed the motherboard to replace the thermal paste and clean the fan.
After I reassembled it, everything is great, except the Touch ID was not working. But the power button is good.
Any ideas about it?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The TouchID cable and the connector interface at the logic board is where you need to check. The cable could have a tear severing one of the lines, at the connector a pin connection could be damaged either by being a bit hard prying it off or pressing on it without aligning it properly before pressing it on with a light touch.
Hopefully you can fix the damage which is still not easy! If you can't repair your options are only replacing the logic board as the button ID key is perm bonded to the given logic board (you can't replace it on its own).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lynn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 227
