跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
VCR won't accept all tapes.
Hi.
I recently started digitizing my old vhs tapes, and i notice curious thing where my VCR won't accept all the tapes.
It takes them in, nothing starts running, and second or two spits it right out.
This won't happen with all tapes, maybe 1 out of every 20 or so, and all thous others play normally, takes in, plays, out, no issues.
I have a fate memory if restoring that small plastic cap was on issue (one that determine when ever or not vhs can be record or not), because sometimes putting a tape in there seem to work but i don't know.
If anyone can help me with this one, i would be grateful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @joonastaahl
What is the make and model number of the vcr?
完成的
Sony SLV-SE100A2
完成的
添加一条评论
1个答案
@joonastaahl
Are the tapes that don't work all the same brand name?
You could try placing a piece of tape over the record tab (where it has been broken off) but I don't think that this would affect playing a tape, only recording to it.
Check if you can manually wind the tapes which don't work, forward i.e. use a pencil etc to wind forward from the large spool and also to take up the tape onto the smaller spool in the cassette. Sometimes with older tapes that haven't been played for a long time, the tape sticks to itself and doesn't budge. Be careful, not to break the tape when doing this.
Here's the service manual which may help if you have to open the vcr to see if there anything obviously different happening inside when inserting a tape that works and one that doesn't.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joona Ståhl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 145
