跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
20 个问题 查看全部
Why will my psp go not turn on?
When the power switch is pressed the green light flashes for a second, but the unit doesn't power up. When the unit is charging the charging light is on, but it still wont power up. When the unit is plugged into the PC it is not recognized. Without disassembling the unit I am not able to do anything else with it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
how to fix psp go wifi not supported
完成的
添加一条评论
5个答案
最有帮助的答案
Nope, no Pandora's Battery for the Go. It has a simple two-conductor battery, that's it. If it has any power at all and isn't starting, it doesn't seem like a mechanical problem, but something wrong with the mainboard. I think it needs a trip to Sony, sorry.
这个答案有帮助吗?
得分 2
1条评论:
You might be able to use the "Pandora Battery" technique to unbrick it. I'm not sure how it's done on this model, but it wouldn't hurt to give it a try.
完成的
添加一条评论
It sounds bricked, you should send it to Sony and see if they will replace it.
这个答案有帮助吗?
得分 1
添加一条评论
buenas mi psp go estando encendida le quitaron la tapa de atras y no encendio mas y le pongo el cargador y prende el led naranja pero no enciende espero y me puedan ayudar sera algun fusible en la placa
这个答案有帮助吗?
得分 0
添加一条评论
Blown Fuse maybe?
http://www.mr-vizitkin.ru/images/stories...
^^ Fuses for PSP GO.
The one on the right is for Audio - so the one *under* the metal shielding may well be your power Fuse. I would suggest testing with a multimeter to confirm.
If you are going to bridge it then a Circuit Writer pen is the easiest - just practice on something other than the psp so you get used to the flow.
这个答案有帮助吗?
得分 0
2条评论:
How do you get under the metal shields?
完成的
Ill be honest with you - they do pop off with a little pressure and a watchmakers screwdriver - just like on an iphone 3g main board. Just *break* the soldered joint and you will be under the shield.
完成的
添加一条评论
you are a !@#$%^& idiot
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 23,619
