跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Always lights orange and doesn't turn on
The console does not turn on and stays lit with orange light. The battery is fine and the cable is fine, but for some reason it thinks it is charging all the time. It does not turn on at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
14条评论
Hi! Please state the model first. It does look like an 3DS XL motherboard, but please confirm. How do you know the battery is fine? It could be battery related. Did you meassured it? If yes, what does it show?
完成的
Hi, it's 3DS old 2011. It isn't XL. I changed it to a working battery. I measured 4.1v in that battery. I took it from a working 3DS.
完成的
Hi! Ah, thanks for the fast response!
Okay, battery should be fine then indeed! Did you checked the fuses on the motherboard? Labeled with "F". You can test them with continuity test.
Thanks!
完成的
I checked one fuse, which was labeled as f1
完成的
It was a working one
完成的
显示更多的9条评论
添加一条评论
1个答案
最有帮助的答案
Yes there are 2 of them!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Quelt gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 74
