跳转到主内容
How to clean the header gasket
How do you clean the header gasket
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @angelamendez
What year is the vehicle, what engine size does it have i.e. 2.0L, 3.0L, 4.4L or 4.6L and what is the problem with the engine?
You don't clean head gaskets.
The only time a gasket should be a concern is if it is "blown" i.e. gasket is leaking which causes the engine to malfunction due to possible oil leaks, coolant leaks, loss of compression, engine misfiring etc depending on where it occurred.
If this is the case it needs to be replaced before any more damage occurs to the engine.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
angela Mendez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 49
