Why can't I turn off closed captioning
After entering settings, general and accessibility and selecting closed caption off, it won't go off.
Hi @ramauer
What is the signal source for the TV e.g. antenna, cable box, streaming device etc?
If other than an antenna have you checked that the closed captions aren't emanating from there?
If not coming from the signal source, try a power reset (disconnect power to TV, press and hold Power button on the TV (not the remote) for 30 seconds and then release it, reconnect the power to the TV and switch on and check if it is still there and if you can turn on/off the captions setting.
If still no good, check for a factory reset setting in the Settings menu and perform that. This will mean that you have to setup the TV again though e.g. scan for channels etc.
这个答案有帮助吗?
Thanks for all your help but nothing works. New tv is on the way.
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 108
总计 673
2条评论
Hi @ramauer
What is the model number of the TV?
Can you turn off/on other accessibility settings OK?
由 jayeff 完成的
Jayeff, model is 43UP80. Other things work.
由 Ramauer 完成的
