跳转到主内容
The fifth generation Subaru Outback began production in 2014 for the 2015 model. This generation is classified as a crossover due to its larger body and wheelbase compared to previous models, and it retains the same 2.5-liter FB25 and 3.6-liter EZ36 engines introduced in the 2013 update.
How to turn it on with a key
How can I use my key to switch the car on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @kisulefredrick
Most cars are started by inserting the ignition key into the ignition key lock located on the steering column and then turning the key in the lock to start the engine.
Are you trying to start the engine remotely, using a fob key outside of the car?
完成的
添加一条评论
1个答案
I'm going to venture a guess your car uses a key fob and with the small emergency key used to open doors. If your key fob battery is dead you can try a few things to start it.
Hold the fob next to the start/ stop button and try to start the car. Some vehicles use a small RFID in the fob as an emergency back-up for starting the car.
The fob must be very close to the receiver on the car for this to work; while that is usually near the start button there is no standard for placement so you may need to search for location on your car.
Try replacing the battery in the fob, most take a 2032 button cell battery. Some remotes retain programming between battery swaps, some must be reprogrammed; this need can change between years of a car model.
Finally if you have the owners manual and have not read it, take a look in the index at the back for which parts mention fobs or keys. Many times you can find basic information that helps with issues like this.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kisule Fredrick 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 17
总计 90
