跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy A22 5G is a mid-range Android-based smartphone developed and manufactured by Samsung Electronics as a part of Galaxy A series. The phone was first released on 24 June 2021. The phone comes with a triple rear camera setup and a 90 Hz display. The battery has 5000 mAh, which is 62% bigger than the battery of the iPhone 13 Pro.
My phone's network disappears
"My phone's network disappears, and as soon as the network disappears, the phone automatically turns on and off, and it doesn't work. Then, when I turn it off, after a while, I turn it on again, and it works for a short while, then the same problem occurs."
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well You can try the following fix it might help you in fixing the issue on your phone:
  • Toggle Airplane Mode
  • Restart Your Phone
  • Reinsert SIM Card
  • Try a Different Location
  • Check Network Mode
  • Reset Network Settings
  • Check for Software Updates
  • Try Another SIM Card:
  • Factory Reset your phone (before factory reset backup your data)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Primary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 75
