跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Battery Performance and Optimization
Hello, my question is quit simple, I used my macbook alot and even my battery is on full, can I use it after 100% charged, does it effect my battery?.
Recently i asked Ai about it and found an anser:
When it comes to MacBook battery optimization, it is generally safe to keep your power adapter plugged in even when the battery is fully charged. Modern MacBooks use advanced battery management systems that prevent overcharging and automatically regulate the power flow to avoid strain on the battery. Keeping the adapter connected at 100% charge will typically not harm the battery as macOS manages charge levels to maintain battery health. However, if you frequently use your MacBook while plugged in, you may consider enabling "Optimized Battery Charging" in system settings. This feature helps to reduce battery aging by learning your usage habits and limiting the charge to levels that prolong battery lifespan.
Please share your experience and expert advise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Different generations have different BMC logic. The 2015 models use an older system from the 2016 models and even the 2020 Apple M Series are different again!
Lithium Ion Battery performance generically is dependent on the physical age of the battery and the number of cycles it has used.
The M Series systems allow you to maximize the batteries life by allowing you to limit the charge at 80% which is the ideal level.
I recommend you install a good battery monitoring App like CoconutBattery
In addition you may want to monitor your Apps power usage using Activity Monitor which is part of MacOS. You might also monitor your system thermals using this App TG Pro as a system running too hot will degrade the battery as well.
这个答案有帮助吗?
得分 1
2条评论:
My question is actually not about draining, I am asking to continuously using it while connecting with adaptor.
完成的
@pixitech - Once the battery is charged it can't accept more power. The charging logic won't allow it.
But depending on what you are doing the power the system requires may require more than what the charger is able to supply as such the power will be augmented by the battery.
If you are asking is there any harm leaving the system plugged in (basically using the laptop as if it were a desktop tethered to AC power. The battery over time looses its ability to hold a charge in your series. The point I was making is the newer BMC logic in the M Series doesn't allow the charge to 100% only getting to 80% for this exact reason. You should let the battery drain down about a third once and awhile to keep the battery healthy.
完成的
添加一条评论
添加你的答案
zubair ahmed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 228
