跳转到主内容
加入维修社区 - 创建账户
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
Keyboard registering wrong keys
I cleaned my keyboard with a moist cloth that was perhaps too moist. Now my right shift key doesn't trigger up anymore. If I press the right arrow it triggers up and I can type normally again. Is it possible to replace the keyboard?
I had a bit more issues, but those cleared up after a night of running cinebench. But the shift key issue remains after a few days.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
See if a hair dryer at low heat can help dry out the wet.
I try to stick with isopropyl alcohol 90% being the best as the lower quality tend to have impurities which you don't really want that can effect the plastics and leave junk behind.
Water is also good, but you need to be careful! You only want to use distilled as that's straight H2O no minerals or salts which can harm your computer's electronics.
As to replacing the keyboard, Apple does not make it easy! They only replace the entire uppercase assembly which is costly! Some independent shops will replace the keyboard alone but the workmanship then becomes the risk as some techs can be a bit hard on the system as you literally need to rip out the keyboard! As it's riveted to the uppercase.
Hopefully the dryer solves your plight !
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christophe De Troyer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 76
