跳转到主内容
加入维修社区 - 创建账户
Mac restarting to prohibited symbol after SSD upgrade
I upgraded the 320gb hard drive in my mid 2010 MacBook Pro to a 1TB WD Blue SSD and it works great, except for one problem. When I click restart from within macOS, the laptop shows the Apple logo for about 2/3 of the loading bar and then changes to a prohibited symbol. It boots just fine from a shutdown and works reliably. The MacBook is running macOS High Sierra, so it’s not a version that it can’t support.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
These old 2010's systems support.SATA 3 Gb/s whereas the WD Blue SSD is highly likely to be of SATA 6 Gb/s which maybe causing a bottleneck. You may need to find an SSD that can auto switch to 3 Gb/s speeds (Samsung is a good brand that can do this).
https://everymac.com/mac-ssd-storage-upg...
This maybe related to your issue.
这个答案有帮助吗?
得分 2
1条评论:
Yes, these older systems struggle with SATA III drives as the data flow overwhelms the buffers. You also run the risk of corrupted files as well as hangs.
If you review the WD Blue SSD it's only a SATA III (6.0 Gbps) drive. Time to find an Auto sense drive that works within a SATA II (3.0 Gbps) system or just get a SATA II (3.0 Gbps) drive.
完成的
添加一条评论
添加你的答案
n3rdbug96 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 11
过去 30 天: 27
总计 167
