Whirlpool fridge freezer combo making intermittent noise
My whirlpool fridge freezer has started making intermittent noise on the freezer side. Attached is a video of the noise.
Asking for any advice on what could be causing the noise and how to fix it.
Thanks!
4条评论
Hi @charlieyahr
Wat is the full model number of the refrigerator?
Are the temperatures in both the refrigerator and freezer compartments OK i.e. approx 37°F (3°C) and 0°F (-18°C)?
由 jayeff 完成的
I don’t have the model number right off.
As far as I can tell, the temperatures are normal.
I got the noise to go away but hitting the back wall panel on the inside of the freezer
由 Charlie Yahr 完成的
@charlieyahr
Sounds like it might be the evaporator fan so knowing the full model number will help to find the correct replacement part if it is the problem.
由 jayeff 完成的
@jayeff
Sorry for the delay. The sticker on the back of the fridge identifies it as ED5FHEXNL. (2 door side by side)
When hitting the back inside wall on the shelf under the ice maker, the sound will change. Sometimes louder, sometimes quieter, sometimes it goes away.
由 Charlie Yahr 完成的
