Why does the camera run down in ten minutes?
I charge the camera - with several new batteries - and it runs down within ten minutes. How can I fix the charging mechanism?
Because the battery in your device has aged, if possible, you can replace the camera or buy a battery to replace it
这个答案有帮助吗?
I have tried four new batteries, and two new battery chargers - and also charging it from the computer.
@jmartz42667 Fast power consumption solution: Turn off WIFI: WIFI function can be turned off when not in use to reduce power consumption. Adjust backlight and warm light settings: Reducing backlight and warm light can lower power consumption. Waiting for the download and indexing process to complete: After the device completes the download and indexing process, power consumption will return to normal
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 91
1条评论
由 jmartz 完成的
