跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
MacBook screen flickering and after while it freezes with blue screen
Hello i recently bought used macbook from internet
Works very find but when i use macbook sometimes screen flicker
i dont know what cause this but i didnt care about it(it happens 1~2times while using 4-5h)
but suddenly it stopped with blue screen or pink brown or some other color
It was working fine until last week so seller is innocent (at least i think so)
I tried nvram reset/reinstall mac os/smc reset/auto graphic change? Disabled
Is there some way to fix it please help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
There are two versions of this series one with just the iGPU (Intel chip graphics engine) and the other with a AMD GPU chip. Do you know which you have? Here's a listing of this series:
If you take the bottom cover off you can see the difference in the heat sink as it will either only have one chip pad or two. Follow this guide to get it off MacBook Pro(15英寸,带有Retina显示屏,2015年中)盖板更换
这个答案有帮助吗?
得分 0
2条评论:
I think it is dgpu model
today it restart after freeze with white screen and it says macbook restart because of crash
I tried apple diagnostics but no error detected
完成的
@suck24877 Can you take the bottom cover off and take a couple of good photo's so we can see, posting them here.
If you got a crash report that would be helpful when diagnostics doesn't pop an error. From the sounds of it it sounds like the GPU maybe failing or just overheating. Are you up to cleaning the logic board and re-pasting the thermal paste on both the CPU and GPU if present.
完成的
添加一条评论
@suck24877 Here is a video on how to do the thermal paste on the CPU/GPU. just in case https://www.youtube.com/watch?v=7912tmng...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Suck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 91
