Repair and disassembly information for HP Pavilion 15 Laptop PCs, specifically 15-eg models. The HP 15-eg is a laptop series designed for on-the-go productivity, featuring 15.6-inch displays, Intel processors, DDR4 memory, and solid-state storage. Identified by model numbers starting with 15-eg.
Jed, give us some more information. You just replaced the battery, is that right? Now you're trying to "calibrate" it and, what, it's not working? In what way? Does the battery charge to 100%? Then you use it until it dies, correct?
What exactly is it doing or not doing? The more information you can give us, the better the chance we can help you figure out what's going on.
With only the four words you've said so far, there's not much we can do to assist you.
you had it right installed the replacement [original hp battery] laptop charges
100% has been working fine. It is HP support Assistant that is installed on laptop that is saying something is amiss with the battery. I have no problems with it. Thank you for so accurately solving the problem with so very little to go on. I deeply appreciate that! JED
由 Jerry Wheeler 完成的
由 JED 完成的
