跳转到主内容
Oppo A37 A37fw 16GB comes with 2GB of RAM. The Oppo A37 runs Android 5.1 and is powered by a 2630 mAh non-removable (as told by Oppo ;-) battery. First released in April,2017.
How to repair a screen senser fillament
screen sense fillament
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I realize this may be partially attributed to language translation, but it's not clear from your question what it is you're looking for. Do you have a broken flex cable going to some sort of sensor mounted on the screen? If so, which sensor is it? How is it broken; is the cable itself damaged, or is it a connector issue?
Pictures are often worth a thousand words, so if you can add a photo of the damage you're concerned about, that would help.
在已经存在的问题里加入图片
The more descriptive you can be about your problem, the better chance we can help. As it is, there's nothing we can do with what little explanation you've given us.
这个答案有帮助吗?
得分 1
添加一条评论
Screen repair
这个答案有帮助吗?
得分 0
1条评论:
Please give us more than two words to describe your problem. Do you want to know how to replace the screen? Is your phone the same as the original question, an Oppo A37 A37fw?
完成的
添加一条评论
添加你的答案
Banicus Lavoisier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 7
总计 40
