跳转到主内容
Repair guides, disassembly information, and troubleshooting for the Logitech M185 compact wireless mouse. Identifiable by part number (P/N) 910-002225.
My scrollwheel doesn't scroll really well (ig it's called jittery)
Hi
so whenever i scroll up for example, the page instead of going up normally, it "jitters", aka scrolls down for a bit and then up, and this happens multiple times
sometimes a slight movement in the wheel will cause it to move a lot, more than normal scrolling
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It is problem with scroll encoder. In my mouse is used Kailh 8 mm. high.
https://www.aliexpress.com/item/10050075...
Best way to replace. Not expensive and buy 2 for the future Better with red core.Temporally You can clean and lubricate after carefully dissemble encoder with spray for electronic contacts or last resort isopropyl alcohol, WD40
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TheCube 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 167
