跳转到主内容
How to open the nose trimmer
Hi,
The title says 'nose trimmer', which I was very happy to find, but the guide actually refers to a beard trimmer.
Someone at our Repair Cafe brought in a Philips-Norelco Series 5000 nose trimmer that stopped working, but it seems to be impossible to open it. Do you happen to know if and how it can be opened?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I found a manual from Phillips about the trimmer. Hopefully this should help:
https://www.documents.philips.com/assets...
p.s. The trimmer has a 2-year warranty as well. So if you still can't open the trimmer and it's within warranty, I would have the customer send an email to Phillips about getting it replaced.
这个答案有帮助吗?
得分 0
2条评论:
Thanks.
The manual doesn't contain anything about opening up the device, of course.
The trimmer is more than two years old, so not under warranty.
完成的
Hmm, I'm not sure then. If I had to guess, there might be some "hidden way" to take apart the trimmer that's difficult to find (I know I'm kinda pulling threads here). I realize it isn't the same trimmer, but I found a good video on where you might find some of those "hidden" areas:
https://www.youtube.com/watch?v=CAqeRzRl...
Try looking around the battery compartment as well to see if there are any areas where you can unscrew something or pop off a plastic cover (be careful not to break it). This trimmer seems very hard to take apart, hopefully nothing is glued together or any plastic melted in place (although I wouldn't be surprised).
Happy repairing!
完成的
添加一条评论
添加你的答案
Tamar Opher 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 23
总计 161
