跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Vertical colour bars on the LCD screen when switched on
MacBook Pro 15.4" Mid 2015 A1398 (IntelCore 2.8 GHz)
When switched on, the display shows vertical coloured bars under which the desktop is partially "readable". The MacBook is virtually uncontrollable. The LCD has no visible external damage (only the black rubber around the display is torn in a few places).
The display is probably not the cause of the problem, as the streaks also show up on the external display (another MacBook with the same configuration) as well as on the 9th gen iPad.
What is causing this problem? Is it the LCD cables, connectors, or part of the logic board (the whole board)?
Thank you in advance for your answers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
This series came in two configs just the iGPU or with a second GPU As you can see here in this listing All A1398 systems
If an external display directly plugged in shows the bars then you’ve ruled out the internal display as well as its cable. What you are encountering is an iGPU (Intel CPU) logic failure, that’s is before the AMD GPU becomes active if present.
这个答案有帮助吗?
得分 1
2条评论:
This is the model: https://everymac.com/systems/apple/macbo...
... is there any reasonable solution to this?
完成的
@radpos - I’m still not sure how you tested things, where you using Target Display Mode or remote connecting via a network connection to the troubled system. The simplest way to isolate the problem is by a direct external display as it remotes other variables. Also we only want to get to the desktop not launch any apps.
So you have a DG version which has a dedicated AMD GPU.
完成的
添加一条评论
添加你的答案
• XRADPOS • 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 79
