跳转到主内容
加入维修社区 - 创建账户
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by a system integrator using off-the-shelf parts.
Why doesn't the PC turn on when I press the power button?
My PC won't turn on even though all the cables are connected to the power outlet.Is the power supply completely dead?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @adiladianjaya
What is the make and model number of the motherboard?
Most likely the PSU is an ATX type so if you have a DMM (digital multimeter) you can perform the paperclip test and check if the PSU turns on and that all the PSU's output voltages are correct.
If the PSU is OK it may be a problem with the Power On button's cable connection to the motherboard or something on the motherboard itself.
Has this PC worked OK before or is this a new build?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Adil Adianjaya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 64
