跳转到主内容
加入维修社区 - 创建账户
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Any way to repair scratches in the screen?
I have a single scratch on my screen about 1.5" long. I'm not looking for a polish to "remove" the scratch as that's simply not possible. However I've seen product in the past that was nothing more than a liquid that you would put on scratches (for example, eye glasses) that would fill the scratch and make it so it's doesn't refract light anymore thus...bye bye scratch, for the most part.
It's been a long time since I've used any such product or have worn eye glasses for that matter. However, has anyone used those product on something like the iPad?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
3条评论
Awesome, thanks Gary! Especially for the actual product recommendations.
完成的
Hey no worries, it's what we're all here for, just let me know if you need any further help.
完成的
The right side of my iPad glass,has chipped glass 1 deep & 1 shallow can I repair with some kind of glass filler? Thnx
完成的
添加一条评论
6个答案
最有帮助的答案
1 Purchase display polish. You can purchase this product from several online retailers and from many brick-and-mortar cellular phone stores. iDrops, Displex Display Polish and AstroShine Clean Kit are three types of display polishes you can use to remove scratches from your iPad.
2 Open the display polish and squeeze a small amount of the polish onto your iPad. Consult the instructions that came with your display polish to determine the recommended amount of product to use for a single application. Typically, you will use a few drops.
3 Polish the scratched area for two to three minutes. Apply heavy pressure using the clean, soft cloth.
4 Repeat as necessary to remove deep scratches.
NOTE
If you find the scratch is too deep to remove with a liquid fill solution, you may have to replace it.
You can find those directions at this link :)
iPad 2 GSM LCD Replacement
For future reference I would suggest buying a screen protrector to better help your iPad from becoming scratched again. If you need further assistance please just ask.
这个答案有帮助吗?
得分 6
添加一条评论
what is this prouduct called
这个答案有帮助吗?
得分 0
添加一条评论
I suggest caution: all these products contain abrasives that remove the special finish that helps prevent finger prints. You may only do more damage to the display surface.
这个答案有帮助吗?
得分 0
添加一条评论
It really depends on the type of material the touch screen is composed of (Glass, Acrylic, Gorilla Glass). I would suggest using a buffing agent that is specific to your type of device screen as to not damage it any further. These guys have it broken down by screen type so you might look into what they have or something similar from another manufacturer.
TDI-LLC Technology - Glass, Acrylic, Gorilla Glass Compounds
Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
c est vrai attention aux produits mais on ne fait pas de miracles !! autant essayer avant de changer l écran ?
这个答案有帮助吗?
得分 0
添加一条评论
F u c k off
这个答案有帮助吗?
得分 0
1条评论:
why would you need to make a comment like that?
完成的
添加一条评论
添加你的答案
Justin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 55
总计 49,056
