跳转到主内容
Msi pro b760m-a wifi ddr4 how to replace CMOS battery
I want to replace battery and wnat to buy which one battery
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @kingsam
Here's the user manual.
Go to p.39 to see how to remove/replace the cmos battery.
这个答案有帮助吗?
得分 0
4条评论:
But there is an iron plate stuck
完成的
@kingsam
Post an image of the motherboard showing where the cmos battery is and the plate.
Here's how to do this in ifixit 在已经存在的问题里加入图片
完成的
Ok i upload the image tq
完成的
@kingsam
That is a heatsink over the IO (Input/Output) IC chip
It's either held on by clips (I can't see any in the image) or it is screwed onto the motherboard
If the motherboard is still in the case you may have to remove it from the case and then unscrew the heatsink from the underside of the board.
Usually the cmos battery model or part number is on the battery itself.
use that information to find suppliers
完成的
添加一条评论
最有帮助的答案
For those finding the CMOS battery on b760m-a, it is right under your display card not inside the heatsink! I cut my finger when trying to reach under the heatsink!!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
king sam 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 50
过去 30 天: 213
总计 1,870
