跳转到主内容
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
Apple Watch Erase all Content and Settings Loop
I'm experiencing an issue with my Apple Watch Series 1 (38mm). Every time I turn it on, I get a prompt with two options: "Erase all content and settings" and "Cancel."
When I select "Erase all content and settings," a progress ring appears, but just before it completes, the watch restarts and shows the same prompt again, creating an endless loop. If I choose "Cancel," nothing changes—the prompt still reappears, and the cycle continues.
Additional details:
  • The watch only turns on when connected to the charger.
  • The side button is not working.
  • Pressing the crown without the charger only shows the Apple logo for a second before shutting off.
  • When clicking "Erase all content and settings," the watch must be plugged in, or else it shuts off after showing the progress ring.
Does this suggest a faulty battery? I’m a student, so replacing the battery is my only budget-friendly option. I can’t afford to upgrade.
Has anyone faced this issue before? How did you fix it? Any help would be appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Well you can try the following:
1. Force Restart the Apple Watch
2. Try Using the Apple Watch App on Your iPhone
3. Restore Using Recovery Mode (if needed)
4. Check for Updates
这个答案有帮助吗?
得分 0
1条评论:
I cant force restart the watch. I cant update it because of this issue. Im stuck at this
完成的
添加一条评论
this problem unsolved since more than 5 years.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marbert Bacanaya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 126
