跳转到主内容
加入维修社区 - 创建账户
The Lenovo IdeaPad S145-14AST is a laptop with a 14-inch display, offering two resolution options and equipped with AMD Radeon R5 graphics, designed for users with basic computing needs. It supports various storage and memory configurations, and features multiple connectivity options including USB ports and an SD card reader.
I Can't get to windows because of the automatic repair loop
It says that the device ran into an error Critical device died or something then it just goes to diagnosing PC screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @rizkinugraha
If Win10 (or Win11) is installed in your laptop and if you have access to another known working Win10 (or Win11) PC create a Windows Recovery disc from the known working PC.
All you need is an 8GB USB flashdrive and 1-2 hours of time.
In the host PC go to Control Panel > Recovery > Create a recovery drive and follow the prompts.
When you have the Recovery USB, insert it into your laptop and then start the laptop and press the F12 key (or Fn +F12) and change the boot order to USB 1st option.
The laptop should then boot from the Recovery USB into the Windows Recovery Environment menus.
When in the WRE menus click on Troubleshooting > Advanced > Startup Repair and follow the prompts.
Note: Be careful if you decide to select Reset this PC instead, because if you select the wrong option next you may erase all your personal data as Windows will be reinstalled.
这个答案有帮助吗?
得分 1
2条评论:
It didn't work it says startup repair cannot fix your PC here's the log file C:Windows\System 32\Logfiles\Srt\SrtTrail.txt
完成的
@rizkinugraha
I can't read a file that is on your computer.
Try checking the HDD as described in this article . Scroll down to "How to run Lenovo's Hardware Diagnostic Tool:" and check if that shows anything.
Not sure about this as I don't know Lenovo that well
完成的
添加一条评论
添加你的答案
Rizki Nugraha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 148
