跳转到主内容
加入维修社区 - 创建账户
Drive won't accept or eject discs
I have a strange problem on an original PS4 Bluray drive. It no longer accepts discs. I have checked the switches inside, they are working fine. I have checked the fuses on the motherboard, no problem with those. I have checked the motor runs, that is fine too.
If I manually load the disc it reads just fine. When I start the PS4 up with no disc in, it goes through the process of trying to read and then the drive load / eject motor runs for a brief second then it just stops. This happens every time which suggests the motor is getting power (ribbon cable looks good).
I've never seen this fault before and cannot find any info on it. Has anyone else had this problem?
Cheers,
Damien
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
On further investigation it appears that the PS4 thinks there is always a disc in the drive. I believe this is determined by the third switch on the motor board, the one that sits apart from the two that sense a disc being inserted. I've checked this and the board connections and all appears to be fine so I guess the only remaining possibilities are the ribbon cable that connects it to the main board or the main board itself.
完成的
添加一条评论
1个答案
Don't know this unit specifically, but original might indicate old. That might point to a belt problem, especially if it has been sitting unused for a while.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the thoughts. Definitely not the belt. It's an issue where the PS4 thinking there's a disc in the drive when there isn't as I can see unknown disc coming up on the dashboard. When I go to eject it the motor runs for a lot longer than usual as I suspect it's not getting the expected feedback from the switch.
I think it's going to be the 5 pin ribbon cable that connects the loading motor and sensors or a fault on either that or the main board, most likely a problem with the connectors or the traces to the sensor switch.
完成的
添加一条评论
添加你的答案
Damien Green 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 44
