跳转到主内容
The Acer Nitro series is designed to provide a high-performance gaming experience at a more affordable price point than some of Acer's more premium gaming products, such as the Predator series.
Acer Nitro 5 an515-31 motherboard short
I had recently decided to get into electronics repair and I'm currently working on a shorted motherboard. The motherboard in question comes from an Acer nitro 5 AN515-31, and the mobo itself is the C5V01 LA E892P. Anytime I try to connect the charger to it, the charger's overcurrent protection trips and it turns off. From what I was able to gather the short circuit is somewhere on the main power line (I tested the inductors in diode mode).
Here are the exact resistance readings between the shorted inductors and ground:
-PL906 6.1 ohms
-PL903 3.1 ohms
-PL904 3.1 ohms
-PL907 13.3 ohms (not sure if this qualifies as a short)
-PL1202 4.5 ohms
-PL1203 4.4 ohms
I'm really lost as to how to narrow down where the short occurs, all vidoes I was able to find rely on measuring voltage to find the short, which in my case is not possible. Since I do not have acces to professional tools, I was thinking of connecting a standard 9V with strong resistors inbetween to try and mimic how those configurable power supplies work, although I'm not 100% sure if it's safe. I'll gladly take any tips you can give me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @mach124
When trying to locate problems on a motherboard (or in any electronics or electrical device) it's always easier if you have the schematic¹ for the device.
¹ For some reason the schematic.pdf file is not displaying everything when you click on it. When it opens click on the download link on the right side of the header bar in the document to download it to your computer. It opens OK with all details when you do this.
Perhaps place one probe of the Ohmmeter on the earth pins of the DC-In jack - see p.41 and then use the other meter probe to chase the +ve input supply on the +19V_VIN and +19VADPIN leads to find out which circuit the short is. Use the search function in your browser when tracing each circuit e.g. search for +19V_VIN etc
Do point to point testing and then unsolder one leg of each component in the relevant circuit, one at a time, from the board to find out when the short disappears.
Also be aware of any possible parallel low resistance paths that may indicate it is a short circuit. By unsoldering one side of a component off the board, if the short circuit disappears, remove the component and then test it in isolation to make sure it is where the short is and not a parallel circuit around that component
In the case of computer motherboards you'll also need a boardview file (here's a link to a free download) and a program that opens .bdv files (search online for one that suits you best).
Nowadays most components on a motherboard aren't designated so by using the combination of the schematic to check the circuit and the boardview file to find the location on the motherboard of the components shown in the schematic, you should be able to find the problem.
Although as most boards are multi layer this may be difficult if it is in the actual board and not a component on the board if you get what I mean.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Denter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 33
