跳转到主内容
苹果公司最小的iPhone 14于9月9日发布,配备了6.1英寸OLED显示屏,先进的双1200万像素相机系统,以及带自动对焦的前置相机。此机型取代iPhone 13。
Where is Bluetooth antenna and can I replace it?
I got an iPhone 14 on eBay with almost unusable Bluetooth connection. If you move iPods more than 2-3 inches away, it’s drops connection. Can’t see any other local devices. I found a replacement Bluetooth antenna online, but no replacement instructions. Oh, the camera had been serviced. Does anyone know where the Bluetooth antenna is? Could the camera replacement have broken the Bluetooth antenna’s connection? Thanks, r
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Yes, the Bluetooth antenna in the iPhone 14 is integrated into the upper antenna flex cable, which is located near the top right corner of the phone, close to the front camera and Face ID components. Since the camera was previously serviced, it’s very possible that the Bluetooth antenna was either disconnected, damaged, or not properly reinstalled during that repair.
Steps to Check and Replace the Bluetooth Antenna:
1. Check for Loose Connections
• Open the phone carefully and inspect the antenna flex cable near the front camera module.
• Make sure it’s securely connected to the logic board.
2. Inspect for Damage
• Look for any tears or bends in the antenna flex. Even a small tear can cause major Bluetooth issues.
3. Try a Software Reset
• Go to Settings > General > Reset > Reset Network Settings to see if that helps.
• Update iOS in case it’s a software issue.
4. Replace the Antenna Flex Cable
• If it’s damaged, you’ll need to replace it.
• Since Apple doesn’t provide official repair guides for this part, you’ll need to find a teardown that covers antenna locations.
这个答案有帮助吗?
得分 1
1条评论:
It is NOT integrated on the upper flex, it's on the bottom left speaker
完成的
添加一条评论
添加你的答案
ralph 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 47
过去 30 天: 158
总计 1,236
