跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 个问题 查看全部
What is the type of SSD in the MacBook Air (A1370)?
I would like to know the exact type of SSD in the MacBook Air Late 2010 Model. Does it use mini pci-e or msata?
Extra question: Does anyone know of the cheapest solution the read the data from the SSD by using normal desktop? (i.e. where to buy the adapter needed for this?)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
I thought the A1370 was the 11" and A1369 the 13"? Anyway the SSD drive uses a custom Apple mSATA connector.
http://www.everymac.com/systems/apple/ma...
If you want to connect the drive externally you could use something like this:
http://eshop.macsales.com/item/OWC/SSDAP...
这个答案有帮助吗?
得分 2
2条评论:
i got a miniSata adapter and it didnt line up at all, neither the width nor the position of the notch. anybody know whats going on? is it proprietary or not?
really dont want to get a special board just to read the data of the ssd.
完成的
@kugelzucker - You need the custom Apple mSATA blade SSD. An M.2 SSD won't work in your system.
完成的
添加一条评论
添加你的答案
Fadhil Ghazali 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 45
总计 20,653
