Windows won't go up or down, and other issues.
I need help! I have a 2013 chevy Cruze and today out of nowhere in the middle of the day the front windows stopped working. When I press the buttons from the master power switch it does nothing. I don’t hear a motor or anything as others with similar issues did. I noticed that the window button for the passenger doesn’t work as well. When I try the back windows they worked, but only from the back door itself. I have no power or control from my driver or passenger side. So, I restarted the battery thinking that my car was just having a brain fart. It didn’t work. Then immediately I thought it was a fuse. I replaced the fuse for the front power windows, and it did nothing. I also noticed at the same time of this happening the radio will not turn off when I open the door, and the key is out of the ignition. This is the first time it’s done this. But I noticed it’s happening along with the window issue. Later that night i notice when I open the front doors it doesn’t trigger the light inside and turn on. Only when I open the back doors it seems to work. So, after hours and hours of research I feel like I’m getting nowhere. I am starting to come to the conclusion that there’s no power coming to the front two doors. If anyone can point me in the right direction. It would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
