跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
okay to reuse battery with some peeled tape?
I recently tried to replace a battery in my antique Mid-2014 MBP 15". I also thought it would be a good idea to replace the trackpad, even though it was still functioning fine. Unfortunately, I removed and then set the trackpad height adjustment screw incorrectly and the left clicks stopped working.
I tried to reach the trackpad adjustment screw without removing the battery first and peeled some of the tape (see pics) off some battery cells. I also tried to fold the tape "flap" on the two center cells to reach that screw, but still couldn't reach it. Is it okay to reuse the battery pack after some of the tape has been peeled:
also, is it okay that there're some 'creases' on the battery cells, see below:
and also, what kind of adhesive/tape would you use for the metal plate on top of the trackpad:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would try using some 3M 5mm Double Sided Tape to put back the track pad cover & also the covers on the battery cells as these absolutely need to be covered, be sure to put the tape in the exact same areas that it was in originally, leaving no gaps around the edges. As for trying to get to the track pads screws without 1st removing the battery was a bit of a risky move as you have just discovered. It is quite easy to pierce the batteries cells, which would seriously damage the battery rendering it useless and dangerous to use again. It could also cause a shorted circuit on the logic board which isn't good news. Regarding the creases in the batteries cells, this is likely due to age? I have seen it many times and I have even seen it present on new batteries, as long as the cells are not swollen up or leaking then it should still be OK. After you have got it all nicely put back together, install coconutBattery and check the batteries status while charging it to see it's actual condition. Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sergio 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 74
