跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
20 个问题 查看全部
iPhone se2 mic1 constant reboot
Hello users, of ifixit. Today, I want to talk about, a device, that I own, that's constantly rebooting due to mic1, I know this issue, is common, with this, specific iphone. Because there's a defect, on the logic board, where the signal, gets lost under, the sim tray. So I took some, diode readings, on the corresponding pins, responsible for the microphone. The following results are 7th pin, gave 0.259, and 8th pin gave 0.279, so I need, second opinion. What do you think, is the likelihood of this issue, the logic board, or the flex charging assembly.🤔
Update (03/04/25)
Update: I tried applying pressure, while testing, the diode readings, on the corresponding pins, for the microphone, there wasn't any significant change, or open line.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The stable but low readings, even under pressure, suggest the problem’s upstream of the flex connector. A shorted cap or corroded trace near the connector (common under the SIM tray in SE 2s) fits the pattern. Water damage or a manufacturing flaw could’ve started it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alkatel Pixi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 7
