A plasma cutter slices through metal by directing air or an inert gas via a plasma torch, triggering an electrical arc, and then pushing plasma through the torch tip, reaching temperatures of up to 45,000 degrees F, making it a swift method for metal cutting.
Thanks for the reply. Yes I have looked they are totally different designs, one is an inverter type the other is a transformer type design. Thanks for the input though.
Hi @terryknox
I realize that you want the schematics for the 375 model and not the 375 X-treme, but was wondering if they used the same pcb board.
Have you checked this link as it has the schematics for 2 different pcb. Maybe one is the same as yours.
Worth a look .
Cheers
由 jayeff 完成的
由 Terry Knox 完成的
