跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Ethernet Part 'Cover' Fell off... Needed or not?
This part from the back side of the Ethernet Port has come off, how to put it back and which way around etc does it go? What is its purpose and can we live without it?
Flat edge down, I think I got it back on best I can, not quite factory but hey.....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@livfe - Not sure where this piece of plastic came from, it’s not from the Ethernet port as you can see here in the iFixit image it’s not there!
Update (02/20/25)
Well, it’s not from the other side either as you can see here
As I hadn’t recognized the part I couldn’t tell you what it was. So… being metal implies a shield function but the metal surface needs to be electronically conductive to the ground plane (chassis or logic board) at least at the higher frequencies and voltages (static discharge) some adhesives can do this as metal dust is held in the adhesive to create the needed pathway.
这个答案有帮助吗?
得分 2
3条评论:
It is not plastic, thin metal... fits in behine the Ethernet Port. Compare to your picture (Top Ethernet Connector) you can see part of it off the side., looking at it I think I put it back on upside down.... Anyway wrong answer ;)
完成的
I have to check it against another board, It kinda hugs the side of the Ethernet Port and it looks like the highlighted 'arm' part would indeed touch the chassis at some place or point... it is a very thin aluminum thing.... It fits from the underside of the board opposite side of the LCD connector.
完成的
@danj I'm glad you discovered a new part! I guess because we never used this Ethernet anymore it won't make any difference there or not..... although I will do my best to fix it back right and hope it don't fall off again and bridge something.... it never had any glue on it, kinda clips in somehow.
完成的
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 113
