跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
iPod touch 4th gen overheating
I replaced a screen and now it seems to get the temperature warning after 10-20 min of playing a game. Could I have done something while changing the screen that would cause this? It isn't the screen itself causing it. A restore and hard reset solved nothing. I don't see anything out of place or broken inside. How does an iPod keep "cool"? My theory is something got damage when it originally got smashed and the screen replacement has triggered the malfunction.....very stumped.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
I would say you are right, I had similar experiences with hot chips and it has to do with shock damage. An iPod touch I had the same problem and it also had a flickering LCD backlight (it would go out randomly and the come back on every 30 mins or so)
I ended up taking it apart and took a heatgun to the chip hoping it might reflow the solder a bit. Welp I ended up frying the chip in the process.
If I was you I would just be thankful that its working half decent and put up with it. If you go and try to fix it, be prepared for a total loss.
这个答案有帮助吗?
得分 0
添加一条评论
It happened to my ipod to try to keep the light below half to save energy and if you jailbroke your ipod try to keep background themes off thats all I got if that doesnt work take your ipod back and get a new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 5,762
