跳转到主内容
Logitech keyboard often bundled with the Logitech Pebble mouse.
Key not working properly
I have to press the Y key aggressively and continously for some time for it to register it. How do i solve it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Well I will suggest you to update your keyboard driver some time any outdated keyboard driver can also cause this kind of issue so you should updater your keyboard driver you can update the driver manually or you can try a good driver updater software which let you update driver without an hassle software like Advanced driver updater is a great option to try.
这个答案有帮助吗?
得分 0
添加一条评论
You're absolutely right! Updating the keyboard driver is an important step in troubleshooting key issues. If a driver is outdated or corrupted, it can cause keys to become unresponsive or behave erratically.
For manually updating the driver:
  1. Press Win + X and select Device Manager.
  2. Expand Keyboards and right-click on your keyboard.
  3. Select Update driver - Choose Search automatically for drivers.
  4. If no update is found, try uninstalling the driver and restarting your computer to let Windows reinstall it.
Using a third-party tool like Advanced Driver Updater can also simplify the process, especially if multiple drivers need updating.
Let me know if updating the driver helps with your Y key issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
DEVANSH VIMAL 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 52
总计 614
