跳转到主内容
A 35mm SLR film camera introduced by Pentax in 1997. It features autofocus and is compatible with a wide range of K-mount lenses.
Overlapping frames and the slipping gear
Regarding "Overlapping Frames: The film advance motor also uses a press fit plastic pinion gear. If the gear starts to slip, the film will not be fully advanced to the next frame. When the next frame is exposed, it will overlap with the previous frame."
What do you do to repair this? Have you found a good Loctite glue for the plastic gear?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Same as me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stig Vidar Hovland 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 24
总计 78
