跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Why is my iPad not able to do anything useful
I have this iPad 2 which had this iPad disabled connect to iTunes issue, I was able to restore it but lost everything but the funny part it is can even install Xender. All it says is iPad is not compatible with this app, same applesize for every app , what should I do, it makes the iPad completely useless
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you backup to iCloud? I suspect you are hitting newer iPad apps that your iPad can’t run. You are likely limited to the older apps which have been removed from the iTunes Store.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 54
