跳转到主内容
加入维修社区 - 创建账户
Repair, disassembly, and troubleshooting information for the Motorola Razr+ (2024), a Motorola smartphone released in 2024.
Has anyone's hinge broken and damaged the screen on your razr +2024?
I bought a Razr plus 2024 in July when it launched and have had nothing but trouble. Two screen protector replacements, then the other day I went to open it and the hinge on the right side broke and bubbled up my screen. Now my inside screen won't work, and the phone hinge is making the phone close a little lopsided. I contacted customer support and, surprise, they won't warranty it because I can't prove that it wasn't damaged by me. Even though it wasn't. I have no idea what happened. I wasn't even rough with it. It is always in a case. I just wondered if that has happened to anyone else and what I can do about it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Literally same ..... right side hinge and all
完成的
I have exactly the same issue with my Motorola Razr + 2024 with not solution yet.
完成的
添加一条评论
2个答案
最有帮助的答案
Same thing happened to me, right side, hinge seemed to like kink or bunch up sorta like it had gotten caught up, bubbled screen and creased the screen protecter into the digitizer of the phone causing the phone to crack. They’re definitely getting their money outta this one, just purchased back in October and just now march.
这个答案有帮助吗?
得分 3
8条评论:
Dropped my phone and the same thing happened. I took it completely apart and one of the hinge mechanisms popped out. I some how managed to fix it and the case opens and closes like normal. I'm going to order a screen and hope this thing works.
完成的
Yes mine did the same thing no drops or physical damage by me it's definitely from the defective hinge only had it less than a month
完成的
Yes my hinge seems to have broken on the right side of my phone screen and has left a little black spot and a green line blue line and a red line going up my screen from the folding spot on my screen .I'm trying to send my phone in for repair or replacement. This damage was not caused by me I think it's a defective part or something. I'm hoping it gets replaced . They told me it wouldn't cost me anything. So we will see . At least I think that's what caused my display to start bleeding ..
完成的
I have the same exact problem except for it was my left side hinge. And now they want $450 to fix it
完成的
That's a defective part on the phone? Why are they making anyone pay for a obvious error on the 2024 moto razr. This should be addressed and fixed without our of pocket from the customers. Like me so I'm sending my phone in to Motorola do you think there going to charge me ??
完成的
显示更多的3条评论
添加一条评论
AI search result:
Issues with Hinge and Screen Damage on Razr +2024
There have been reports of hinge-related problems leading to screen damage on the Motorola Razr +2024. Users have expressed concerns about the durability of the foldable design, particularly with issues surrounding the screen protector and hinge area.
Common Problems Reported
  1. Hinge Mechanism Concerns:
    • The hinge area often becomes the weakest point, leading to potential stress on the display. Users have mentioned cracks forming near the hinge over time.
  2. Screen Protector Issues:
    • Several reports indicate that the inner screen protector tends to develop cracks, specifically around the hinge. While some users stated that this is common with foldable devices, they also warned against attempting to peel the protector off, as this could void the warranty and further damage the display underneath.
  3. Display Malfunction:
    • Symptoms of malfunction include touch responsiveness issues and visible warping of the display, especially at the fold. In some instances, the display has been reported to peel without any external impact, which raises concerns about the quality of materials used.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kassie Lynn Oxford 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 49
过去 30 天: 193
总计 2,242
