跳转到主内容
The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
I think problem in motherboard how to resolve it
I have replaced my note 8 batteries at least 3 to 4 Times ,but it breaks my back panel and got fatty. It automatically switch off while using and when I turn on this handset ,it shows 0% battery and switch off again. It can be a motherboard problem- if yes then how to resolve it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If your phone suddenly switches off while using and then shows 0% battery when you turn it back on, immediately switching off again, the most likely culprit is a faulty or worn-out battery, which is no longer able to hold a charge properly and is likely nearing the end of its lifespan.
A few reasons why this might be happening:
  • Degraded Battery
  • Battery Damage
  • Loose Connections
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Parvinder General Store 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 88
