跳转到主内容
加入维修社区 - 创建账户
The phone stop's charging at 75 percentage
Why is that the phone stop's charging at 75 percentage it won't increase until i turn off the phone then it continue charging
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Bagaimana cara supaya baterai hp saya tidak gampang lobet meski msh d 75%...
完成的
Garam hora ha mobile
完成的
添加一条评论
2个答案
If your phone stops charging at 75% and only continues charging when you turn it off, this is likely due to a built-in safety feature to prevent overheating, which is triggered by heavy usage while charging; when you turn off the phone, the heat generated reduces, allowing the battery to charge further.
Key reasons why this might happen:
  • Overheating protection:
  • Most modern phones automatically limit charging when the battery gets too hot to prevent damage; turning off the phone reduces heat generation, allowing charging to resume.
  • Battery health:
  • As your phone's battery ages, its ability to hold a charge can decline, causing the phone to stop charging at a lower percentage to prolong battery life.
这个答案有帮助吗?
得分 0
添加一条评论
Change charging port.👍100%
Another check setting battery safety enable
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
muneer 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 28
过去 30 天: 62
总计 429
