跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
After changing the battery my MacBook Pro won't boot up
I changed the battery on my 2018 macbook pro with a kit from Ifixit and now it's dead. It won't even try to start. I have dual boot with a one partition having windows and the other partition mac os. Before starting the repair, I set the mac os partition to be the automatic side to boot up and then followed the instructions to turn off the auto boot. The old battery was swollen and giving some problem but it had been working. The repair went perfectly, so I can't figure out what's wrong.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Check the MacBook Pro 15" Retina (Mid 2018-2019) Battery Daughter Board Cable is not damaged as well as the ZIF connectors are latched per Step 1 in this guide 认识和断开线缆连接头 here after re-inserting the ribbon cable we need to carefully fold the latch down to compress the cable.
Replace the small flex cable that connects the battery daughter board to the logic board.图片
产品
$14.99
这个答案有帮助吗?
得分 0
2条评论:
I checked that connection and the other ones too. Everything is fine. Can the cable be damaged even if it still looks good? I checked the battery voltage after charging it for an hour or two and there was no increase. So I don't think the battery is getting any power. Is it possible that something happened to my logic control board when I took it out?
完成的
@jms83415 - Over bending and sharp creases can damage the cable. Could you have damaged to ZIF socket? Post some pick on the connections here so we can see get in tight with lot of light.
As the battery was swollen and if the battery had already been replaced before then it’s possible the charging logic within the logic board is having issues.
Let’s get a better view of things install this gem of an App CoconutBattery post a snapshot of the apps main window here as well.
完成的
添加一条评论
添加你的答案
jms 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 139
