跳转到主内容
The Acer Nitro series is designed to provide a high-performance gaming experience at a more affordable price point than some of Acer's more premium gaming products, such as the Predator series.
Acer Nitro 17 freezes when playing games
This laptop is relatively new as I have only had it for only about a year. This started as a minor annoyance that only would happen every once in a while but now it has become nearly impossible to do anything on this laptop that puts any kind of stress on it, primarily gaming. What happens is I will be playing a game and after about five minutes, the screen will go black and totally freeze. The lights on the keyboard continue to change colors and everything but I have to manually shut it off with the power key. Sometimes it will bluescreen but that has only happened about three times. When it has bluescreened, it has given me the codes, stop code: CL and clock_watchdog_timeout. This is getting very frustrating and for the more than $1,000 I spent on this laptop, I would expect it to work perfectly for more than just a single year. Also I have ran many deep malware scans and there are no viruses of any kind. Any help would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you open Device Manager, you can see if there are any devices that may need driver updates, and updating the drivers could resolve your issue. You could also use Event Viewer to see if you can get more information about the problem, or use Windows Memory Diagnostic to check for memory issues.
这个答案有帮助吗?
得分 1
3条评论:
Are there any specific drivers I should check? I checked many of them but every one I tried didn’t have any updates. The memory diagnostic didn’t bring up any answers. I have already checked the event viewer everytime it has bluescreened but never really got the answer I was looking for. I feel it’s either my ram or OS based from some other forums that I have read on other sites and from researching the error codes I received from the BSOD but I’m not 100%. I’m just trying to be sure before I start taking stuff apart or going through backing everything up. My windows is completely up to date as well.
完成的
@shelby53409 If you want to use the system file checker to see if it may fix the problem, you can open a command prompt and run sfc /scannow to repair your system files. The problem with system instability is that it can have a lot of different causes, so it's good to rule out as many causes as possible through hardware checks. Your BIOS may also provide options for hardware diagnostics, or have an option to change all BIOS settings to their default values to see if the BIOS settings may be causing problems. From what I've looked up, the clock_watchdog_timeout error seems to be related to the CPU, so you might want to check BIOS settings related to the CPU. If you do end up opening the computer, I would check for possible CPU cooling issues, but I try to err on the side of exhausting all software-related solutions first before resorting to opening up the computer.
完成的
Also, while you're in the command prompt, you can use chkdsk /r /f to check your disk for errors. It might fix the problem, it might not, but regardless it's good to run occasionally.
完成的
添加一条评论
check your drivers. I had that issue with my own laptop I received as an Xmas gift even tho I don't use it for gaming, but instead for college work. What's the specs for the laptop? 16 or 32GB ram? Intel or AMD CPU?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shelby 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 22
总计 74
