跳转到主内容
加入维修社区 - 创建账户
a7R II(型号 ILCE‑7RM2)是索尼 2015 年推出的全画幅、微单、可换镜头相机。
Why won’t it turn on?
I sold my a7r II on eBay to a person who bought from me before. It was returned as non-working. The unit worked perfectly before it was sent out. Now after return it is a brick. All screws are in the exact pattern they were in, no damage or evidence of tampering on the outside. I’ve tried multiple batteries and usb cables - there’s no response. Any ideas what inside to look for and what parts may be involved?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @unclevanya
Speculating as to what might have happened considering you said it worked before you sent it and not upon its return is that, either something internal in the camera came loose in transit or if a fuse is blown (see below) the user may have used the wrong value charger (if you didn't supply a charger with it) to charge the battery whilst it was in the camera.
According to the parts list for the camera it uses 2 different rated fuses.
Unfortunately the service manual doesn't show where they're located but I think that they may be on the SY-1058 board (see p.9 for location of the board)
Here's an image showing the location of several fuses on the SY-1058 board. If a fuse has blown, search online for Sony (insert fuse part number) to find suppliers that suit you best.
Guess you won't really know until you open it up and check.
(click on image)
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I’ll look at how to access that and put it in the todo list.
完成的
添加一条评论
添加你的答案
UncleVanya 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 320
